Ls1pcm will works on ls3 engine?
Old 02-19-2013, 08:48 AM
Jeff Smith's Avatar
Default Ls1pcm will works on ls3 engine?
Can't find serach here..
I have red/green pcm and red/blue pcm from 2001 ls1. I plan put new Ls3 engine in 2001 Camaro.
Old 02-19-2013, 09:53 AM
joecar's Avatar
Default No
LS1 CKP/CMP signals are 24x/1x (and the 24x is encoded).
LS3 CKP/CMP signals are 58x/4x.
You would have to change the crank reluctor and cam sprocket, or use the signal converter that LPE makes (if it's still available).
Old 02-24-2013, 12:29 AM
AVB
AVB's Avatar
I did it w/ the LPE converter and love the LS3
Old 02-24-2013, 01:15 AM
baileydirt27's Avatar
Have the LS3 in mine using the factory PCM and works fine. Sprockets where changed to 24x though.
Quick Reply: Ls1pcm will works on ls3 engine?
