can i adjust shift points with intune?
Old 02-27-2013, 05:15 PM
PaSteLaSo4U's Avatar
Default can i adjust shift points with intune?
Stock 2.73 rear end kicked the bucket and just wondering how much out of wack the shift points would be going to a 3.23?? Can the diablo intune be used and if so, which parameter? I was thinkin just adding rpms to the rev limiter but I guess that's not the best approa
Old 02-27-2013, 07:25 PM
LS1Tech Sponsor
Mike@Diablosport's Avatar
Yes, you can use the inTune to reprogram the gear ratio to correct the speedo and shifting.
You can also make adjustments to WOT and part throttle shift points and firmness if you desire
Old 02-28-2013, 05:19 PM
thanks, so if I go up on the firmness, it will have a less lazy wot shift?
Old 02-28-2013, 05:28 PM
LS1Tech Sponsor
Yes
Quick Reply: can i adjust shift points with intune?
