Pro-M sensors and FI
I am looking at Pro-M's 117mm MAF Sensor for my major FI LS1 build and I have questions. Can I use this with the stock PCM? Does it just plug in to the factory harness or does it need an adapter? Can it be pre-calibrated to allow minimum MAF tuning on LS1-edit? I don't wish to go to a FAST or Gen7 controller... yet. I want to see if it can be done with the stock computer.
Did you ever get an answer to your question about the Pro-M
Thanks
Bryan
So to make sure I understand there was nothing fancy or special about using the Pro-M. I have a blown application, and want to be able to tune for air induction above 4200RPM without having to guess on the fuel. I have so much air that the Stock MAF cant read anything after that. I am also using LS1 Edit.
Please confirm Thanks
Originally Posted by stealth
We're currently trying to get our car running using the Pro M and translator. Yes you can use the stock pcm. We are using LS1 edit but you probably get by without it.
Coal Mining Director
It's my understanding that it does not help if you use a stock 85mm maf or a +100mm Pro M since the computer is maxed around 512g/s.....doesnt matter which meter tells the ecm that you're flowing 600g/s....the computer still can't adjust to it. Only benefit to a larger maf is the lessor pressure drop from the maf restriction itself....if they both are giving out an accurate readings of 600g/s the larger maf may be worth an addional 10 rwhp since your supercharger isn't have to blow as hard or push as hard to get thet 600g/s through it as opposed to an 85 mm maf.
I don't know that I was looking for more power per say, I really wanted to be able to better adjust the mixture, but it sounds like the stock computer is the problem here. I guess in the PE table I will just have to make very small fuel adjustments and run it on the dyno until I get the right combonation.
If you have any other suggestions I am all ears.
Thanks
Bryan
