Wideband Through EGR and Stalling!
Old 05-10-2013, 02:46 PM
bfurches's Avatar
Default Wideband Through EGR and Stalling!
Looking for some help if anyone else has experienced this issue...
I am using the standard HP Tuners VCM Suite. I recently decided to take advantage of data-logginf my wideband (AEM EUGO), so I ran the 5v line through the EGR position wire (pin 55 on the blue connector).
After making the custom PID and etc...when I enable EGR, it works just like it is supposed to....but the car won't idle...just stalls.
If I go back and disable egr, the car runs fine but the sensor wont log (obviously).
I guess the PCM is seening voltage on the line and trying to compensate for "egr" position that is non existent....but where?? I don't see any tables that would affect this???
Anyone else experience this issue?
The following users liked this post:
eddierm250 (12-29-2019)
Old 05-10-2013, 04:29 PM
wild1100's Avatar
What type of vehicle some didn't have a pin 55 pinned I am running It thru the ac for that reason. Im no guru just had similar issue.
Old 05-10-2013, 05:17 PM
bfurches's Avatar
1981 Caprice, 2006 L33 with 2001 Intake harness and PCM (originally had EGR).
Regardless...I think I figured it out.
I was looking at the tables and there is a VE subtractor when EGR is open (even though it is not installed, it is now seeing voltage on the signal wire via the wideband and interprets that signal as "OPEN").
I believe the solution is to zero out the following table in my application:
Engine>Airflow>General>EGR Airflow values
I will report back tomorrow if it solve my problem.
Quick Reply: Wideband Through EGR and Stalling!
