new to tuning and need help. how do you change maf sensor from fbody to truck style? how do i change the injector sizes. need to go from 36lb truck to 42 lb ls2 injectors.
You're going to get told to buy the Banish DVD's, which do help, but the injector information isn't exactly all they're made out to be. To start, look in the repository to find what you are looking for...chances are at least someone out there has the same MAF and injector combo you are running. you can also search the boards if nothing is in the repository.
After you find what you are looking for and have a "base", you'll need to get a wideband and start tuning the MAF and VE tables.
Best of luck to you, not a whole lot of help out there anymore if you're trying to learn how to tune your own stuff.
Edit: Actually read your question and all the data you need will be in the repository since you are using OEM parts...still need to tune it to your app though.
