OL SD Tune issue
OL SD Tune issue
I need some help figuring out where I need to make adjustments in my tune. Its an 02 OS running 2 bar speed density with no o2 sensors, 6.0 , tx giant cam,60lb injectors,and a turbo..
I finally got around to adjusting idle air flow and getting everything somewhat stable but when the motor is running hot around 216ect the stft goes way past 125 and wideband goes off the scale on leaning out.
Now it doesn't seem to do this all the time , like when I run the idle air config in scanner , I ran it close to this temp and didn't have a problem with AFR.
SO basically it seems it has to be in the fueling as the spark is steady at 25 and iac acts normal until it leans way out and trys to compensate.
Is there any other table besides the VE table that could relate to a temperature or any other factor that can impact the fueling so drastically maybe a failsafe mode..something im overlooking?
Besides this I have everything pretty close to dialed in for driveability.
