Fuel pump signal wire from PCM a 12v or ground signal?
So I already screwed myself by wiring my fans NOT knowing they are ground switched from the PCM so I had to rewire that. Now the green wire that comes from the pcm to trigger the fuel pump, is that ground switched also or is that a 12v source that I can use to turn on/off my fuel pump relay on my Leash board?
LS1Tech Sponsor
Don't know what type of car or year but traditionally GM has used a hot trigger from the PCM to the fuel pump relay.
__________________
See what's in our shop on Facebook! Customer Build Blogs!
www.pcmofnc.com
Performance Installs - Dyno Tuning - Custom Camshafts & Valvetrain - Remote HPtuners Tuning - Mail Order Tuning & Sales
704-307-4227
www.pcmofnc.com
704-307-4227
