Left Bank is running REAL LEAN after H/C Install....???
Old 04-26-2004, 07:38 PM
2002C5COUPE's Avatar
Default Left Bank is running REAL LEAN after H/C Install....???
I just finished installing my ported LS1 heads and my TR224 cam, and now the car won't idle after it warms up and the left bank is showing real lean (on a snap on scanner). Ive replaced both primary O2 sensors, checked the intake and exhaust gaskets.....what else could it be????? any help would be GREATLY appreciated!
Old 04-26-2004, 08:00 PM
HumpinSS's Avatar
VACUUM LEAK somewhere are all the intake bolts tight. Make sure you didn forget to attach any of the hoses
Old 04-26-2004, 09:38 PM
Bink's Avatar
Check your Left AIR tube also.
Old 04-27-2004, 10:37 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,110 Likes on 728 Posts
Sounds like an intake leak.
Old 04-27-2004, 03:37 PM
ok more info now.....its alternating between left and right banks. first one will be rich and the other lean, then it switches....i think im going to take it and have the PCM reflashed at the dealer.
