P0103 MAF Help!
P0103 MAF Help!
So my car keeps calling a p0103. I have tried cleaning the MAF as well as the air filter. All the wiring/sensors look ok visually. Is there anything else I could try or am I stuck buying a new MAF?
The car is a 383 LS1 with the fast 102/nw 102 and all the bolt on goodies. I don't think it got wet and no I didn't clean it when it was hot. I was going to eventually upgrade to the TSP 100 MAF and FTP 104 Lid but I was trying to make my current setup last a bit longer.
Very possible you are at the hard limit of your MAF. Do you have any scanning or monitoring capability? You want to review your MAF frequency during a pull. I think the hard limit on your MAF is 11500 Hz and will set that code. Either way you can see how it is behaving while you drive. Cheap scanning solution is Torque App on an Android phone. EFI-Live or HPT at the other end of the spectrum.
