Tuning the warm start with ac/defrost on...
New cam old problem crops up.
Just wanted to vent how a painful process this is dialing in the fine details. I miss my old cam already.
MAF dialed in on a dyno with wideband (2500-6800rpm) check
WOT dialed in on a dyno with wideband. check
SD dialed in from idle to 2500 check.
It's just a matter of time till I get the right VE settings for it. Last time I fixed it on my old setup with a swap to 85mm maf and dialing in the MAF table. I was even able to run a 800 rpm idle...
