HELP!!!, LS2 swap : removed the VATS and its now cranking but no start!
Old 10-17-2013, 10:42 AM
Kamaro's Avatar
Default HELP!!!, LS2 swap : removed the VATS and its now cranking but no start!
Hi all,
I just installed a LS2+T56 with the original wiring harness + E40 ECU (from a 2005 GTO) into my '70 camaro, I added the fuse/relay box from current performance and made the original harness as a stand alone one, everything went on fine, and I logged in to the ECU and disabled the VATS, but even so the engine would turn when I hit the start but its not firing up, I checked that I got a good grounds all over the place, the ECU do get a switched and battery 12V, I even checked if the coils/injectors get a 12V and it was all fine, I spent the whole yesterday night all the way till 8 am this morning with no luck, I already lost half of my head's hair! , the only fault codes that I get is the EVAP solenoid and fuel tank pressure (the pic shows all the DTCs), ans I attached a copy of my HPT file as well.
Any kind of help would be highly appreciated.
Hamad
Attached Thumbnails HELP!!!, LS2 swap : removed the VATS and its now cranking but no start!-imag0324.jpg
File Type: hpt
Old 10-17-2013, 11:42 AM
Joe1967ls's Avatar
Did you check for 12V while cranking, it was my problem on my first swap
Old 10-17-2013, 02:02 PM
sparkwirez06's Avatar
what do you change to disable the vats?
Old 10-17-2013, 05:48 PM
Kamaro's Avatar
VATS was disabled from the OS general drop menu
TCS patch .. Applied
VATS 1 .. Disabled
VATS 2 .. Disabled
Old 10-17-2013, 09:44 PM
2xLS1's Avatar
Did you do a write entire? A write calibration only won't disable it.
Old 10-18-2013, 07:18 PM
Kamaro's Avatar
I tried that, sill no luck!
I got spark, but no fuel.
I searched all over google and they are talking about applying VATS patch, is that a separate file that I need to get or do they mean just simply change the "TCS patch" to "applied" in the HP Tuners VCM Editor?
I still get DTC code P1629 (Theft deterrent).
Old 10-18-2013, 11:33 PM
Kamaro's Avatar
yep, that was my problem, beside a small mistake with the wiring, fixed both and it fired right up!
thanks bro!
Quick Reply: HELP!!!, LS2 swap : removed the VATS and its now cranking but no start!
