who is doing stand alone pcm tunes??
this is what i need:
~Engine Type & Year: 2003 4.8 out of a truck, PCM does NOT match engine
~Has truck fuel rail with the 4.8 injectors, injectors # is 25317628
~I'm running a mechanical trans a 1986 TH400 so disable automatic trans diagnostics, change VSS to 8k pulse per mile
~Remove Emissions (EGR, AIR Injection, EVAP System, Rear Oxygen Sensors) remove all
~Remove Computer Controlled A/C
~this is a engine swap it is inside a 1986 chevy truck
~I'm using the oem Mass Air Flow Sensor
~remove any anti-theft (VATS)
i seen that most guys use the guy off off lt1swap aka (Brendan Patten)
but i have emailed him several times with no response,
so what else is out threre???
