LS swapped mustang o2 sensor question
I wasnt sure if I needed to post this here or the hybrid section.
What I have is a fox body with a lq4 swap. the computer that was used was fom a 03 escalade. the wiring harness is from a 02 escalade. I need to replace the upstream 02 sensors. Every part house shows a different o2 sensor for the 02 vs 03. The only difference I can find is the harness length.
What sensor should I buy. I would think with them both being 4 wire that they are the same sensor. What about the universal 4 wire units? Any good?
Thanks for the help!!
