Easy 98 to 99-02 f-body harness repin labels inside!
Anyone that might ever repin a 98 f-body harness for a 99-02 PCM might want to save these 3 word documents. Print them out on Avery 8593 adhesive backed "folder labels" (like $5).
Match the strike through text pin number to the 98 pin number as cast into the aluminum PCM connector body. The corresponding 99-02 pin number is on the right of the label in bold text. There is also a description of the circuit, and what color the 98 wire should be. Just match the 99-02 pin number on the label in bold to the pin numbers cast into the 99-02 aluminum PCM connector body and your good to go! No fumbling through wiring diagrams trying to match everything up in the field.
I spent a fair amount of time on these, and I figured I would pass them along! Enjoy.
https://www.dropbox.com/s/tj07smf869...93%20LABEL.doc
https://www.dropbox.com/s/6ohdcyhj4k...93%20LABEL.doc
https://www.dropbox.com/s/jj5ou7iexr...93%20LABEL.doc
EDIT: Missing are emissions, rear 02s, fuel tank/ gauge wires, and the cluster coolant wire. That should be *pretty much* everything missing. This is for a swap application so those are not included in my labels above. You can check the wires you have left after exhausting these labels and fill in the blanks for your application. I figure anyone doing this on an f-body will most likely not be needing the emissions or rear 02 wires anyways, so really you should only be left with labeling the fuel sensor, fuel gauge, and cluster coolant wire on your own!
The following users liked this post:
JoshuaGrooms83 (07-28-2022)
no biggie, just wanted to see some more info before I start mine. seems pretty straight forward with the MRK instructions. My biggest thing now is trying to figure out which pcm holder to use lol
