less whp without dyno fan
Hi . I have dynod a 99 camro cam only on a dyno dynamics and it put down with the fan on and got a 399 whp . That day temp was about 77 . Few monthes later I dynoed it with out the dyno fan on same modes and temp was about 68 degree and it droped to 345. Same tune same modes sothing added to the car even fuel air ratio was right the same way when I ran it 2 monthes ago .. so could it have been the dyno fan not working caused this drop .
If the cooling fan was not used, the engine will run hotter. That can allow detonation, which will pull timing and add fuel, which can cost you power.
On any given day, you'll get different numbers from the same car and same dyno. Normal and expected variance.
But you lost almost 55hp, 14%. That's a lot. I'd be looking for something going wrong. How do the spark plugs look?
Did you save the logs on both runs? If so look at the IATs during the runs. Even still that sounds like a huge drop off. I'm going with leak down and compression test
No I didn't take the log nore I checked the plugs . On first run it made 360 . And on the second it dropped to 245 . At the same day we ran a t67 supra and it made 368 but it had traction issue and on the second it dropped to 350 then we waited for 30 mints for it to cool and re run it and and it went to 389 I guess I would check the pluggs and try a run with fans on plus I still think ambiant air and engine performance are the issue I'll try to run it again with new plugs this week cause tge plugs are about nine months old but I dont drive the car much
Checked the plugs they look perfect and like I said the fuel air ratio seems fine . Engine compression also was fine .. no exhast leak . So wouldn't u guys think its the fan that caused the drop of whp . I would realy like to find out. I will fix the fan and re run the dyno again
