Diagnostics port not working!?!?!?!?
My car is a 2002 z28. I had exhaust work done and afterwards my diagnostics port not working. I have a predator programmer thats turns on but when its time to read the ecu it says turn the car on when its clearly on. So i went to advance auto and used the scanner they have and i get the same problem. Anyone else have or had this problem??
LS1Tech Sponsor
any aftermarket electronics?? like aftermarket/non-factory stereo, subs, amp, alarm, remote start, etc etc? if so, you need to disconnect them/pull the fuse for 'em...
and also need to make sure your key is turned to ON position....
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Yeah I do have aftermarket parts but they was installed years before exhaust work was done. The problem started right after I picked my car up after the exhaust work. Could welding on a car cause the diagnostic port to short out. The scanners is getting power but none of them can read the pcm
