secondary ve table
Old 05-14-2004, 03:59 PM
FDLS6's Avatar
Default secondary ve table
was modifying me primary ve table, and noticed there was a secondary table. When is this secondary ve table used? Thanks,
Bryan
Old 05-14-2004, 04:38 PM
Bink's Avatar
I believe it was for open loop or PE fueling PW in early PCMs. The overall pattern is the same with Less precision in the secodary table owing to fewer cells - MAP/kPa axis. Many/most of the MAP cells (40, 50, 60, ...) are identical between the two tables (primary vs secondary).
Maybe one of the Gurus will jump in .....
joel
Old 05-14-2004, 10:59 PM
FDLS6's Avatar
thanks for the feedback. If anyone knows what circumstances call this table, i'd appreciate it.. this is a pcm from a 2000 ws6. Thanks
Old 05-18-2004, 03:02 PM
P Mack's Avatar
So when tuning for idle, there is no need to do anything with this table, correct?
Old 05-18-2004, 03:40 PM
TIMMEH's Avatar
from what I've been reading yes that's correct.
Old 05-18-2004, 03:48 PM
Bink's Avatar
No need to change at idle.
joel
Old 05-20-2004, 10:37 AM
gameover's Avatar
secondary VE is only used during failure (such as MAF DTC) on early code.
