Running a gen 3 motor with an e38 PCM
Old 04-18-2014, 08:39 AM
98TA6.0's Avatar
Default Running a gen 3 motor with an e38 PCM
I currently have a gen 3 5.3 in my truck with a 4L60E. After witnessing a friend with a sprayed/pulled CTs-V beat he **** out of his 6L80E without even a hiccup I have decided I want to run that trans. I have a fresh 6.0 in the garage that I would like to convert to work with a harness that will operate the 6l80e. Is it possible to just change the reluctor, cam/timing gear, sensors and intake/TB to allow the use of that PCM? I have HPTuners and will build my own harness for my swap. Any input would be greatly appreciated
Quick Reply: Running a gen 3 motor with an e38 PCM
