Which MAP?
Old 05-12-2014, 10:02 PM
Root2812's Avatar
Default Which MAP?
So I have a 2000 5.3 that is going into a swap with a stand alone harness and a LS6 intake. Since I get both intakes I have two separate MAP sensors and I'm not sure which to use. The original truck MAP is part# 16249939 (black label) and the one that came with the LS6 is part# 16212460 (blue label). Should I use the one that came with the motor or with the intake?
Thanks
Quick Reply: Which MAP?
