Running 80lb inj/3bar n/a on microsquirt?
Already have 80lb Deka inj and a 3 bar map on my lq4 build was just wondering if the car will still run ok n/a before I do a turbo setup ? It's getting nice out and I'd like to start driving it but if it won't run right with that setup I will wait and do the turbo . Thanks
It'll run like a turbo car out of boost I'd imagine. Anything below positive pressure is basically n/a in my thinking. Just tune your spark table and fuel tables below positive pressure like you would a n/a setup. Unless my thinking is wrong, if you can't get it to run good n/a, it woulnt run good boosted either while cruising or doing anything other than smashing the pedal.
Hope my line of thinking is correct as I'm running holley 120's on a build right now that's not boosting til winter. I'm using hpefi tho. Should tune out the same....
