3 bar sd problem
3 bar sd problem
Need some tuning help. Setup up as a 3 bar sd tune no o2 sensors no maf 2005 5.3 with t56 76mm turbo lunati cam 595/595 242/242 114 lsa. Anytime the engine builds boost it loses all power and shuts off the electronic pedal. Have to turn engine off for about 30 sec then start again to get it work again. Any ideas? Here is my tune basically a copy of a similar setup.
Tried google havent found anything. Made a couple changes just gets worse and worse no matter if I got back to the old setting or not. Heres a copy of the tune and a log. This is in the garage in neutral.
Went back to my old map write entire. Set my pid to 3 bar os. Now runs fine until wot pull then REP mode. There are no codes no couplers are collapsing kr isnt picking anything up.
