No vss signal to speedo or solus scanner
Old 07-19-2014, 12:39 AM
novaskilling's Avatar
Default No vss signal to speedo or solus scanner
Hey guys recently put a 2005 L33 in a 72 nova. Had a 6 speed behind it but I've switched to a 4l60e. I have the vss installed and plugged in properly but I'm not getting any signal to my speedometer or on my snap on solus scanner. I replaced the vss sensor itself and still no luck. Any help would be a life saver! Thanks very much.
Old 07-20-2014, 07:35 AM
sreve's Avatar
recheck your work, make sure wires did not get pinched between eng. and bell housing. check continuity between vss plug and pcm.
Quick Reply: No vss signal to speedo or solus scanner
