VATS issue
VATS issue
Did a VATS bypass last year and it has worked great up to this point. Now it's acting up again. I plan on looking when I get home to make sure the resistor is still connected tight but has anyone else had a problem with it post bypass? Maybe the resistors go out? I'm no electrical genius so its a little out of my realm of expertise. Any advice or guidance would be much appreciated.
to curew it you have to do the resistor and also turn it off in the pcm or you will get a 1626 i think is the number . Or if you want you can find the starter relay under the dash and cut two wires and put them together and bypass the resistor .
