how to bypass the dbw?
Im going to swap a ls3 in my camaro and wanted to know if there's a way around the dbw
im trying to keep the 58x harness and ecu and run a super victor and 4150 tb dbc.
You will need to use a 2002 Camaro pcm & harness. LPE sells the 58x to 24x reluctor adapter module so that you don't have to change the reluctor wheel. As there is no drive by cable vehicle that use the 58x reluctor.
http://www.lingenfelter.com/mm5/merc...3#.VE2oU1djeik
Russ Kemp
Russ Kemp
I did it once....but it was a dbw tb that was converted to a dbc....You lose iac...The tps in the dbw tb was still used. I have the thing around somewhere but it wont help in your quest.
