2 different issues
2 different issues
I get a lean spike when mass air is plugged in.[ frame 212]
92614scan lean spike.hpl
So ive been driving with it unplugged and 3 different times it has a bog under acceleration that has not lasted long then it goes back to normal. I did get to log it yesterday and timing is getting pulled to 0.5 [frame 212]
bog.hpl
tuneknock retard removed long term fuel trims turned on 2 timing increase up to 29 ricend up PE and .hpt
bog.hpl
Not sure if anyone has looked at log file, but one thing I noticed was the afr was were it was suppose to be when it was bogging. Wondering if im loosing rt. bank of cylinders with a bad connection on the coils. the afr is in the left side. would loosing one side cause it to cut timing?
Finally figured it out. TCC Relay was stuck and didn't open when the brake was pushed some how causing ETC to cut timing. First I disabled ETC LIMITS and the bog stopped and then when driving I realized the converter was acting up. Then I remembered talking to James whom had mentioned the brake sw. because it was bogging if I brake torqued it. I didn't think much about it at first because it had never bogged on the line at the drag strip. So driving to work yesterday I realize the TCC relay and wiring could cause this so I checked and sure enough the relay wasn't opening.
