2wd vs 4wd 4l80 segment swap
I'm about to shoot myself. I have been front to back. Vss sensors are putting ac all the way to the pcm. I checked everything 20 times. Found a 10amp #0ign fuse blown. After replacing it the trans shifts fine no more limp mode stuck in 2nd. However I have no speedo, no cruise, and abd/parking brake lights are on. Also no odometer. The only thing I can think of is the company that did my seg swap used a 2wd. Again mine is 4wd could the pcm be looking for the vss in the transmission vs the tc?
I did a segment swap on an awd van when I did a rossler 4l80e swap. It was not 4 wd, but I dont believe it was a different segment swap than a 2wd.
Sounds like the segment swap maybe is incorrect or corrupted? I did have a problem with mine, but it was years ago.....and I just dont remember what it was.
