NGK/NTK to Hptuners help.
I just bought HPtuners pro but I'm yet to hook my wideband up. Its got two loose wires on the harness of the wide band so I assume thats where they attach to my interface. I'm just not sure which terminal on the interface each wire goes in. The wires on the harness of the wideband are green and grey.
http://www.hptuners.com/help/vcm_sca...connecting.htm
After you connect, type the tuning school wideband into google and you will find a PDF write up on how to configure.
Hope this helps.
Hope this helps.
Right now I have the green wire in pin 4 and grey (maybe called black) in pin 5. I right clicked in the chart display and added ngk wideband into the chart. Thanks I'll try it Monday
