Ignorance To Tuners, ME! Looking for CRATE Motor/ECU support.
Hey all, I need some advice on picking the RIGHT tuner. I've got some experience with Dynojet Power Vision tuners on my Harley. It has a module that can be mounted to the handle bars and you can auto tune and watch any parameter that the ECU can read. This is what I'd like to do with my LS3 motor. I've got a GM crate motor with a GM stand alone harness. I've asked Diablo and they say they don't have any support for crate motors. Anybody know who makes something for a crate motor that will self tune and has a small monitoring device that can be mounted to the dash. I'm thinking that the reason they don't support crate motors is cause there's no vin number to lock their device to. Thanks much.
You know the MS3pro, microsquirt, EFIsource gold box, setups can output a CANbus signal straight to the 996 dash, to run the instruments.
And has for a couple of years now.
This route in not for the "check book" builders, there is some engineering, and re-engineering involved, but you would be going down a path others has been down.
http://www.msextra.com/forums/viewto...orsche#p314742
The drive by wire, on an LS3 wouldn't be controlled by a MS install tho.
Have you looked at the Holley Dominator? It will do everything you want including running drive by wire and control 4l60e and 4l80e and paddle shift. They have a 5.7" lcd to make changes in tune load tunes + monitor and log. They just came out with a dash that is around a 7" screen. It does have a self tuning feature that works really well but only for fuel tables. Many are using a windows based tablet for a dash.
