wideband histogram-15kpa is boost. need fix
My wideband is currently not reading correctly. It only reads from 15 kpa to 35 kpa and that's wide open throttle at 6 lbs and with one 9 lbs spike. I don't know what gives.
I change to the 2 bar map under the display table (manifold air pressure 2 bar)
I even tried adding the regular map (manifold absolute pressure-kpa) back and it didn't change any thing.
I'm lost and confused and can't do any ve tuning till this I solved.
BTW I never touched my wideband pid and it worked just Fine when I was N/A. So there's something I'm not setting up right in the scaner cfg
