pin out help
pin out help
Does anyone have the pin outs and diagrams for the wiring of both a 97 s10 and a 2000 silverado? I am attempting to splice both harness's together. Budget is tight otherwise I would just by a stand alone harness.
silverado is on LT1Swap.com s10 not sure but look. make the silverado harness and tie it in. you should be able to tie most over at s10 pcm connector probably.
