LQ4 Tuning, no knock sensors?
Old 04-22-2015, 12:36 PM
gagt3100's Avatar
Default LQ4 Tuning, no knock sensors?
how would I tune timing with no knock sensors? Is there a stand alone system that is somewhat cheap i can buy? engine is in a 90 mustang
Old 04-22-2015, 12:52 PM
2xLS1's Avatar
You can run a GM PCM with no knock sensors. Just turn the KS codes off. Then you tune by listening for knock rather than the scanner showing it. Not sure why you would want to though.
Old 04-22-2015, 05:07 PM
gagt3100's Avatar
the engine does not have knock senors in it right now, and I don't know if the harness has the plugs for it
Old 04-22-2015, 05:16 PM
murphinator's Avatar
Old 05-13-2015, 03:09 PM
gagt3100's Avatar
any other info on this? how would I tune timing?
Old 05-14-2015, 06:54 AM
Old Geezer's Avatar
Question Maybe..
start by looking to see if the harness has the plug[s]??
Old 05-14-2015, 10:20 AM
LSX Power Tuning's Avatar
On a load bearing dyno would be the best way.
Quick Reply: LQ4 Tuning, no knock sensors?
