05 GTO knock sensor problems
After doing my cam/ported heads and tune my car starts throwing circuit 1 knock sensor low input and circuit 2 knock sensor low input. I found the driver side wires melted together next to the header. I replaced and rerouted the wires and replaced both knock sensors 2x. I have also added another good ground from the header to the body. Nothing helps. Can it be in the tune? Any suggestions would be greatly appreciated. Thanks
If I use my Diablo sport slp and try to load one of those tunes will it save my custom tune so I can reload it? I'm trying to see if it's in my tune. Before it will load a tune it backs up the factory tune, which is my custom tune right?
