tune for ls6 intake
tune for ls6 intake
I have a head/cam 6.0l, it has a really good tune on it currently. I'm still running the gen3 truck intake with a 78mm dbw tb, I'm going to be swapping to an ls6 intake and keeping the 78mm tb, how much work is it for a tuner to make the changes for the new intake?
If you're previously tuned then it'll just take recalibration of the ve table(s). As long as the airflow path before the MAF is unchanged then it will still be fine, if the timing was previously set correctly then it should be fine.
