High idle issue
High idle issue
I am having an idle issue and i just did a scan and was wondering if anyone can look at it and tell me if you see anything out of the ordinary? Im VERY new to tuning so bear with me. When you start the car the idle will hang around the 2500 rpm mark...(it used to be close to 3000RPM until i adjusted the idle screw a bit today. Its on a 1998 Camaro A4. I have replaced all of the vacuum lines and put on new intake and TB gaskets. I had the problem prior to that and thought changing all of that would fix it....it didnt. Thanks for any help.
Andy
Andy
