E10 gas and O2 sensor readings
Old 10-08-2015, 06:19 AM
Bill00Formula's Avatar
Default E10 gas and O2 sensor readings
I know 02 sensors aren't too accurate far from stoich but if I remember correctly I always heard they should read around 880 at wot and 900 plus was on the rich side. With E10 gasoline should the target be closer to 900? I just want to confirm my wideband sensor readings. Thanks
Old 10-08-2015, 11:07 AM
LSX Power Tuning's Avatar
You can not double check your wideband with your narrow bands at WOT. A narrow band is not accurate in that range. Only way to check your wideband is with another wideband or read your plugs.
Old 10-08-2015, 06:48 PM
Thanks for the info.
Quick Reply: E10 gas and O2 sensor readings
