408 ls with 200 shot
You have a few options one is to change your base spark table this will reduce timing n/a and on spray. Second you can get a timing tunner it will adjust spark when the system is active. Third you can do an IAT trick to switch to the lowest IAT cell and take timing out then all the options have good and bad.
