Deatschwerks Injector Voltage
I have a set of ls3 65lb injectors and I am trying to get a base tune figured out for start up, using a Holley HP. The software needs the off time info vs voltage but I can't find that info anywhere and it's not on the flow table card that came with them. I looked at their GM calibration data but still couldn't find what I need. Anyone else using a Holley ecu and these injectors? I may just be reading the table wrong? Thanks
I spoke with them a few times though email and got some information. I think I may just be under-qualified to translate their charts to what I need lol. Can you tell me if the injector off time curve is the same as battery offset?
On there website the have the data. Find your injector data there and show it here and i am sure someone can help.
If i was you i would call http://www.lsxpowertuning.com/index.html . They are very helpful on this website.
Here is a link to the GM calibration data for my injectors
They also have a battery voltage offset wizard on their website that gives the data but they said that the data is outdated and they wouldn't recommend using it. I compared the data that comes up in that wizard though and it matches the few voltage points they give in these charts I posted a link to.
