How do I disassemble 6l80/90 connector?
Hello.
I need to disassemble the 6l80/90 connector that is on my harness. We haven't been able to communicate with the TCM, and found that the bus wires are backwards.
I think this white clip is the retainer for the pins, but I can't seem to get it to pop out.
Any ideas?
Any ideas?
The following users liked this post:
bigmoe128 (09-02-2023)
The side with the small white section only needs depressed. NOT THE BIG SIDE with about all of the white expose. Then you need a de-pin tool with a plunger to de-pin the connector. Sorry I don't have a part number available for the tool.
We figured out how to push the white section out of the way by pushing on the small tabs, but then realized we needed a tool to de-pin it. So, wanting to get moving, we cut the wires, swapped and soldered them back. Not how I wanted to do it, but it worked.
