Gauge cluster help on 99 Silverado with 04 ls swap
99 Silverado k3500 "classic" body style with 04 ls engine. How do I make the speedo work? Also the oil pressure and coolant temp. Any help would be much appreciated.
Head on over to LS1truck.com,lots of tips there,get the pin-over sheets from Lextech over there.Have you re-pinned your truck to the LS PCM? You can use the speedo and tach output to your cluster,get an adapter for your 99 oil sender(LS pcm doesn't need oil pressure input),you will need to tap the right side head for the 99 water sender or fit it into the rad hose.
