Innovative wideband users: Does the inductive rpm pickup work?
Is anybody using the inductive pickup? Does it just clamp to one of the plug wires? I've heard of problems with inductive pickups, where they can't keep up at high rpm.
Thanks,
Dan
Thanks,
Dan
Kurt,
I haven't ordered the unit yet. I've been narrowing down the other brands out there, I ended up going full circle and am back to the Innovative. I'll have multiple cars to use it on, so I figured the inductive pick up is the way to go (instead of chopping up multiple tach leads). For twenty bucks, I'll just order it up.
Keep me posted if you get a chance to try it out. I may take you up on the offer to check it out.
-Dan
-Dan
LS1-Edit and autotap right now. Need to get a wideband, then I should be all set. With better tires and a good a/f tune, I'm looking to dip down into the 11's and add a couple mph. Maybe add a rollbar and dry shot over the winter.
