Diablo Trinity and LQ4 tuning
I swapped an lq4 into a 1998 Trans am. Ported heads. Cam. Stock Ls1 intake (don't judge me). I recently came across a great deal on a diablo trinity. They're usually $500-600. But I found it brand new for $250. My car runs but it needs to be tuned. So my question is can I delete the front O2's and the egr system on the device? Or do I still have to take it to a tuner?
LS1Tech Sponsor
no you can not.. still would need a custom tune done in order to disable codes, etc..
and the FRONT o2 sensors are the ones that control fueling/fuel trims... you don't want to disable those.. you have to have those installed and working correctly..
the REAR o2 codes can be disabled..
the handheld is going to go by the VIN number on the pcm so it knows what preset canned tune it would be able to install.. and if it's your stock pcm, then it won't work, because 1998 is not supported.. and if it's the pcm that came with the engine, be it a truck or whatever it came out of, it would think that is the vehicle it's installing a tune for, which won't necessarily be what you want for your car/tranny setup...
with being a swap, and with the cam/heads, I would take it to a shop to get done...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
LS1Tech Sponsor
if it's a 1998 pcm, then no, won't work at all on it..not supported..
__________________
Moderator
You have to repin the entire harness to get a 99 PCM to work. It is not trivial; and I believe that some wires have to extended if you want to keep the PCM in the stock location. In other words some wire are too short to reach to their new position in the connectors.
I would suggest contacting e.g. one of the tuning sponsor for a mail order tune to your '98 PCM.
