85mm MAF....4 wire vs. 5 wire?
Is one better than the other? What car did each go on? I busted my 75mm one (my finger slipped inside while putting it on and broke one of the wires ) so I'm just going to go all out this go around. I want the 85mm as it should help out the 388 but I need to know which one to use. I was thinking if I can use the Z06 one I could just copy over the stock Z06 MAF table in LS1Edit and be set. Sound right?
Thanks
Thanks
