LTFT's: VE vs IFR
LTFT's: VE vs IFR
With the advent of tuning the main VE, would the proper way to tune be leaving the IFR tables stock (assuming stock injectors), and tweak your LTFT's slightly negative by creating a new VE table?
Once the table is created by capturing a gazillion samples, how do you determine which cells to change to get your LTFT's slightly negative? Which direction would use to raise/lower the LTFT values?
