Problem with ls1edit
Old 08-03-2004, 09:17 PM
Public Enemy's Avatar
Default Problem with ls1edit
hey guys, i ordered ls1edit v1.4 from carputing for my 2003 holden monaro..
when i recieved it, i installed the program, went through the user guide and connected the cable and everything was fine..
I went to ls1prog so i can read the PCM so i can get my flash file.. after that i went to 'connect' but it doesnt read.. it says communication error, whats the problem? the cable and everything else is fine!
Old 08-03-2004, 09:38 PM
red ws6 99's Avatar
You need to select which com port the cable is connected on and make sure the key is in "ON" position but not running. If you are using a usb-serial converter check all the settings. Some people have had problems with the various different models, try turning off hardware flow-control if its a usb adapter. The belkin units are hit or miss, the keyspan units more stable.
Gary
Old 08-03-2004, 09:44 PM
2000_Silverado_SS's Avatar
ya go to settings and select the right com port. Mines in com port 4.
Old 08-04-2004, 04:16 AM
Billiumss's Avatar
What they said....
BTW - Version 1.5 is out now, you should have gotten an email from Ken with the new update!
