Zo6 Maf
Zo6 Maf
Installed a ZO6 maf on a 2002,Adjusted the IFR to get the LTFT into the proper readings.But every time you make a change the car will not start unless you unplug the MAF, get it running and then plug it back in,Has anyone ever had this problem ??
Take your IFR table back to stock and goto http://www.ls1howto.com/index.php?article=25 and change the maf tables the values listed here
Z06 maf
