Harlan Shift light install problems
red- to 12v
black to ground
green to tach wire of pcm, on a 98 it says Blue connector pin 35 white wire.
My problem is when i hook the green wire to the white wire the cars tach goes dead, it reads nothing.
Any ideas why? As soon as i unplug the green wire the car tach work agian.
This is on a 98 Z
black to ground
This is on a 98 Z
Double check the # on the wire you are splicing, I know when I hooked mine up on my car I had to be very careful to choose the right wire. On mine its# 10 and it's white, I had a hard time reading the number on the plug and there were a few other wires the same color on the same plug. If you havent already done this.
