94 Lt1::Going from 52mmTB to a 48mm stocker????
I am selling the car and the 52mm TB is not going with it, so I am replacing it with the stock 48mm. My question is what programming changes do I need to make? I am using Tunercat and I have a mail order tune that was programmed for the 52mm. Thanks in advance.
Okay...figured it out. The clamp that holds the CAI to the throttle body had pinched the bottom of the elbow and so it didn't allow it to fully install onto the throttle body. Well this caused the throttle body to get an excessive amount of air after the mass air..Needless to say once I fixed this, the car idles just fine
