Accel Gen 7 and MAF-less
Is the accel Gen 7 setup to run a MAF. Somone told me the kit does not even come with wire provisions for it.
I think I am going to run a Accel unit with my car because I will be using a Kinsler fuel injection IR intake manifold (Like Hilborn Style).
I'm pretty certain you don't need to run a MAF with it and can go strictly speed density. this is a good thing.
this system does not use the o2 sensors either correct.
And you were not too clear on wheather or not the system comes with MAF wires. I know I do not need to use a MAP, but does the system even have provisions for a MAP.
Thanks.
Thanks.
Unless you have a special option- it probably doesn't use a wideband O2.
MAP is necessary and the system will come with an appropriate (probably 3 bar) MAP sensor.
Thanks.
Thanks.
