How to get rid of abs light after 9" install
Old 10-18-2004, 08:10 PM
zaner's Avatar
Default How to get rid of abs light after 9" install
I have a 98 Trans am does anyone know how can someone get ride of the abs light after a ford 9" rear end install... it cant be done thru any type of ls1 edit or anything i found out... I saw a writeup on project transam on how to do it on a 96 model f body, i wonder if it the same wires coloring and fuses on my car... any one have a clue
Old 10-19-2004, 10:46 AM
Turo's Avatar
pull the gauges then pull the bulb out, or put a piece of electrical tape on it
Old 10-20-2004, 08:57 AM
Ultra Z's Avatar
bulb is made into the panel so you must seperate the panels and put tape over the spot where the abs light shows threw
