Transmission Tab / Shift Speed
Old 10-25-2004, 04:35 PM
Dumb Ass Vette Moderator
ls1290's Avatar
Default Transmission Tab / Shift Speed
What is the difference between Norm Shift RPM, Hot Shift RPM, and Pref Shift RPM columns?
I believe that C5 do not have a normal/performace mode switch, so should the Norm Shift RPM and Pref Shift RPM columns be the same?
When is the Hot Shift RPM column used?
These three columns are for WOT shifting and the 4 left side side buttoms are for non WOT correct?
For the four non WOT buttons, when is the Hot Normal Shift Speed and Cruise Mode Shift Speed tables used?
Lastly, to determine when the WOT or non WOT table are used, that is determined by the Engine Cal-> Fuel -> Wide Open Throttle -> WOT Cold / WOT Hot correct?
Thanks,
Keith
